air compressor help
Started by David Anderson, August 26, 2009, 09:13:40 AM
David Anderson
My Harbor Freight air compressor had a capacitor meltdown.  It was running fine, attempted a restart and couldn't turn the motor.  I pulled it out of the bus and one of the capacitors has a melted spot on it. (see picture).  Would it be worth trying to replace the capacitor or should I replace the whole compressor.  It has been very reliable.
The capacitor is listed as 70uF +/-5%  MK SH
250Vac  DB HPFPU, 50/60HZ   25/7021              There is another set of numbers lower on the case:
CH0012083-96  E2026163
Len Silva
Absolutely, change out the capacitor, not a big deal and not all that expensive.
Make sure that the unloader is working properly.  If the compressor tried to start against a loaded head, that might have caused the capacitor failure.  More likely it just failed on it's own.
Sojourner
Change capacitor would my choice for around 10 dollars. Whatever, never replace it with lower voltage rating. The higher uf (mean larger physical size) the better starting power but might snap the drive shaft.
Quote from: Len Silva on August 26, 2009, 09:37:50 AM
Amen!
The bottomline is keep it cool air via outside air and exhaust the heated air will increase compressor's life.
And keep draining the pump's air tank to avoid too many unnecessary restarts.
Example
Sojourn for Christ, Gerald
David Anderson
Why does the compressor have 2 capacitors??
David
Len Silva
You have a start capacitor and a run capacitor.  This will explain it better and simpler that I can.
http://www.allaboutcircuits.com/vol_2/chpt_13/9.html
JohnEd
Do what Gerald and Len said.  Always keep elect stuff as cool as you can....within reason.  Caps are less sensitive to temp than the motor would be.  If this compressor is in a closed space you should consider a ventilation fan of some sort.  Regardless.....run it for a while and then feel the side of the motor.  Real warm is OK.  Hot is not.
David Anderson
Phooey,
I found a new start capacitor, installed it and the compressor ran like a top, for about 3 minutes.  All of the sudden the capacitor began to enlarge, then kaboom.  It exploded and sprayed this gooey stuff all over my shirt.  I unplugged an inspected it.  The goo was oozing out.   Oh, well, I fired it up again and it started right up, but after about 50 seconds the capacitor started smoking and was super hot to the touch.  I did this about 5 times and it always started and ran fine, but lots of smoke.
I assume the start windings in the motor are seized or something.  Anyway, I now have a new compressor and I'll use this one for an extra tank.  Sometimes it just doesn't work out the way you want it.
David
JohnEd
David,
If your start circuit was bad it would not "start".  It is the run winding that is shorted.  Time for a new Harbor Freight motor.  Yours may still be under warranty.  The replacement motor would be a cheap item.
I handed them a torque wrench that went breasts up today.  Didn't even have to fill out a form.  Just got the replacement off of the shelf and walked out....with their permission. ;D  Now who said the walking around with an assault rifle slung was not a good thing. :o ::) Just kidding about the rifle. ;D
David Anderson
The compressor was 8 years old.  I got my money's worth.  Time for a new one.
David
