Almost had new glass in bus - Page 2
Started by NewbeeMC9, July 10, 2009, 07:00:34 PM
Melbo
good luck I hope it works this time
Melbo
I'd call MCI and ask about the gaskets! I know for a fact that MCI, C & J, US Coach, and and many others will have them in stock! The outfit you are using just don't want to pony up the $ for them!
FWIW!
NewbeeMC9
They did it!!! :) :) :)
the new glass is slightly undersize than the first one, they sanded and deburred the edges,
did not trim the gasket
didnot use the silcone caulk on gasket to body but used spray silicone for lubricant, even on lock bead
used spray foaming windex for lube on glass,  I think it goes away too quick.
