rebuilt genset radiator enclosure
Started by Tenor, June 27, 2009, 07:01:12 PM
Tenor
Here's a shot of my old setup.
I found out that the old squirrel cage fan inside the enclosure was DOA.  The new one was about 2 inches wider so I swung the whole assembly over.  It also now uses the original circular access hole in the rear bulkhead to pull hot air out of the genset enclosure.  We had 85 degrees and the genset ran at 175 degrees while running 2 roof airs, inverter charging batteries, and the fridge.  I love it!
Glenn
Glenn Williams
Lansing, MI
www.tenorclock@gmail.com
2001 MCI D4500
Series 60 Detroit Diesel
4 speed Spicer
JohnEd
The smell of success and the taste of victory.  And your cool too. 8) ::)
looks good,
Looks good!  If the duct tape does not hold, try Gorilla tape at Home Depot.  Good Luck, TomC
Tenor
Thanks Tom!  I know I need to rebuild the panel that faces the side of the box since it has excess holes from running the radiator hoses for the previous location.  I figure, test first, build to spec later!  ;)
Glenn
Glenn Williams
Lansing, MI
2001 MCI D4500
4 speed Spicer
Lonnie time to go
Thank you for posting photo's .  It helps a newbee like me to setup my bus
I do hope to see you at the "back to the bricks" rally in flint  Aug 13-16
1976 4905
Tenor
Hey Lonnie!
Yes, Amy, Matt and I will be at the back to the brick rally.  Will you have the bus there?  It's a great excuse to go for a drive!
Glenn
Glenn Williams
Lansing, MI
2001 MCI D4500
4 speed Spicer
Lonnie time to go
I am not sure if the bus will be there trying to get some tires.  If that goes well i should have the bus there.
1976 4905
