A/C questions
A/C questions
Started by Airbag, April 06, 2009, 05:36:32 PM
Airbag
I have procured the copper tubing for my run between the evap and comp. There are two lines, one is a 1/2" and the other is a 1/4" line. I believe the 1/2" is the return from the evaporator and is the one that needs insulation. I also believe that you never want the two wraped in the same insulation correct? The 1/4 does not need insulating correct? Sorry for my ignorance.
PP
Hi Rick,
Glad to see you making progress with it. On the existing ones, the 1/4 is not insulated, just the 1/2". Hope this helps.
BTW-thanks for the info on the ariel photos. Unfortunately, dialup takes a long time to see anything. I'm looking forward to the next time I get near WiFi.
Will
Hi Rick,
if you can, make a "Vibration loop"  with both copper lines at the condencing unit. A one ft. round should do just fine.
This will reduce the chance of a refrigerant leak in the future by absorbing vibration from the compressor.
You can loop them after you insulate the larger suction line.
Good Luck
Airbag
Nick as always thank you and I will getter done. I cut the hole thru the floor tonight. I am committed to this.
Will thanks also. I understand about the dial up. We have no high speed internet at my airplane shop. I built a Beech Starship using a dial up to locate parts. I am still having nightmares about watching blue bars creeping across my monitor. I now have broadband there, it is a little bit faster.
