Clutch Problem - Page 2
Clutch Problem
Started by Lin, April 03, 2009, 10:03:16 AM
Melbo
Lin
When I did the tranny I also did the engine (L10) and air throttle integrated steering etc etc.
So the price of the tranny is lost in repower and upgrade
Melbo
Lin
Melbo,
Sounds like an amazing upgrade.  I am not anywhere near making a commitment like that.  If I could do the tranny for 5k, I probably would, but that is not likely.  I would also switch to integral power steering, but that's about it on the major stuff.
Just for information if anyone is runs into a similar situation: After talking to Fredward I decided it was time to learn to shift without the clutch.  If I had known it was so simple, I would have been doing it long ago.  I don't think it would be so easy without a tach though.  Since I can use the clutch to start and stop, and then shift without it, it seems that the bus could be usable this way for a while.  My exercise in clutchless shifting further convince me that the clutch has problems since I can shift smoothly with the clutch as long as I am tweaking the rpm's as if I was not using it.  This would seem to indicate that normal double clutching is no longer working to synch the gears.  Anyway, since I do not really know much about the mechanism, my theory may be just superstition.  Any expert enlightenment would be appreciated.  Thanks for all the responses.
