Where can I buy a new wet bath?
Started by Oregonconversion, March 31, 2009, 12:00:19 AM
Oregonconversion
I am looking for an all in one shower/toilet/sink that is preferably fiberglass or plastic. Anyone know where I can get one? It will save me the hassle of building one myself.
1977 MC8
8V92 HT740
Sean
AFAIK, all wet baths are custom-molded for the application.  While there may be only a handful of companies molding them, each RV manufacturer is supplying either dimensions, templates, or molds.
To buy one ready-made, you'd have to settle for one of the designs already in the market, and persuade either the RV maker or the fabricator to sell it to you, or find one at a surplus dealer.
On this last possibility, I would check with the surplus outfits in Eugene, OR and Elkhart, IN (several listed in the archives here, or a Google search will turn them up).  With several manufacturers going belly-up over the last year, you might just get lucky.
Remember, stock wet baths are tiny.  Typical applications are truck campers, class-B's, and small light-weight travel trailers.
Good luck with your quest.
there is a place in Portland called Miles Fiberglass that builds custom fiber glass showers.They built mine if they have the mold you like the price is not bad if they can be modified for your needs.If a new mold is required hang on big bucks       good luck
johns4104s
Luvrbus,
We also may be in the market for one what price range do you consider reasonable?
John, I gave 500 for mine with the top molded into it to match the roof line.I didn't want the ceiling materail exposed to the humidity from the shower.    good luck
Sean
Quote from: luvrbus on March 31, 2009, 08:19:09 AM
John, I gave 500 for mine with the top molded into it ...
Did that include a sink and a mount for the toilet, which is what the OP is looking for?  Or was that just a shower?  I suspect the former, which is a much more complex mold, is a bit pricier unless it is surplus.
Sean, mine was for the shower only but they have the units that are made for marine use my friend Kevin has one in his bus not the way I would go but each to his own   good luck
