Needed MCI Brake pedal thingy
Started by BC Bus, March 10, 2009, 03:56:46 PM
BC Bus
I need a thingy.  Sorry I don't have a part number but I will do my best to explain the part.   This bracket is bolted to a bulkhead in the spare tire compartment and has a rod that connects to the brake pedal.  When the pedal is depressed this pushes down on the treadle valve and applies the brakes.  It is mounted right above the treadle valve.  Someone stole mine.  The treadle valve is still there and so is the brake pedal.
I need one for a MC 8 or 9.
GMC Buffalo  &  MC9
Always willing to help a Busnut !
gumpy
Suggest you call Sam Caylor in Rantaul KS. He'll have what you need.
Or maybe someone on here will be scrapping a bus and will send you one.
