Alaska
Started by Brian Diehl, February 23, 2009, 11:40:19 AM
Dallas
Sam,
To get a relatively useful idea of mileage from point "A" to point "B" just go to google and type in your starting point, (City and state "to" your destination point, (City and State) hit enter, then look in the upper left corner and click on "Maps"
The screen will change to google maps and give you mileage, a route and estimated time.
You can also change your route by grabbing the blue line on the map with a left mouse click and pulling it to where you want it. The map will recalculate automatically.
For instance, I just did Savanah, Ga to Anchorage, AK and came up with 4615 miles, 3 days 5 hours of travel.
Then I grabbed the blue line and pulled it over to Minneapolis, MN area and the map recalculated to 4596 miles and 3 days 6 hours travel.
I'll leave the difference in travel time up to the user to figure out, but it is logical, based on speed limits etc.
http://maps.google.com/maps?hl=en&q=Savannah%2C%20Ga%20to%20Anchorage%2C%20AK&um=1&ie=UTF-8&sa=N&tab=wl
Quote from: Sam 4106 on February 28, 2009, 08:28:04 AM
Hi Brian and Gumpy,
I am not going, but my neighbor wants to and we were discussing distance to Anchorage. I based my estimate on the fact that four couples that I know that have gone and put on about 10,000 miles for the round trip. I thought my neighbor just wasn't being realistic about the distance and the cost. We are good friends so there were no ruffled feathers. I tried ask.com and all I could get was the "as the crow flies" distance of 2625 miles. I'm not very computer literate so I thought Craig could give a better answer. Thank you both for your help.
Sam 4106
Sam 4106
Hi Dallas,
Thanks for the suggestion, but there seems to be a slightly optimistic calculation on the time required to travel from Savanah, GA to Anchorage, AK. First, the travel time of 3 days 5 hours would require you to travel 77 continuous hours. Second, it assumes a speed of 60 MPH over that 77 hours. While the distance of 4615 miles fron Savanah to Anchorage may be correct, the distance from Minneapolis to Anchorage can't possibly be. The difference 4596 miles and 4615 miles is 19 miles, and I know the distance between Savanah and Minneapolis is farther than that. It would probably be out of the way go from Savanah to Anchorage via Minneapolis but not that much.
Thanks, Sam 4106
gumpy
Ok, well, let's see what the log book says....
Odometer read 94884.9 when we left St. Michael.  When I filled in Anchorage, it read 98962.0.
So that's 4077.1 miles.
Again, that's not a direct route from St. Michael to Anchorage.
Oh, and our final odometer was 104283.0.  So total mileage for the AK trip was 9398.1.
Dallas
Sam, I wasn't talking about moving your starting point from Savannah to Minneapolis, but rather changing the route taken....
the original route went through Iowa and South Dakota, but by grabbing the blue line with my mouse and pulling it to the Minneapolis area, it changed the whole route and so recalculated the distances.
Try creating a route with the directions given before. Once you have that, move your mouse to the blue line that shows on the map as your route. As soon as you are on the blue line, hold down the left mouse button and it will grab the line. Without letting up on the button, move the mouse somewhere else. Now let go of the button, and, Viola! your route has now changed.
Good luck.
Dallas
Quote from: Sam 4106 on February 28, 2009, 02:08:14 PM
Hi Dallas,
Thanks, Sam 4106
Sam 4106
Hi Dallas,
Thanks for the clarification. My brain doesn't work nearly as well as it used to. Thanks again for helping.
Sam 4106
akroyaleagle
Joe Laird
'78 Eagle
Sioux Falls, South Dakota
