Spray foam kits +/-
Started by ilyafish, December 23, 2008, 12:13:41 PM
Sojourner
JohnEd...about your post in regard to the air breathing toxic fume. That is a good post to be in Wiki file by all mean.
We need that reminder to keep us informed of the human safety.
You said it well and by no mean always follow the product's recommend safety suggestion on all of MAK board posts.
Thank you JohnEd!
Sojourn for Christ, Gerald
Merry Christmas!
John316
John,
I can see that you have spent a lot of time thinking about this issue. I am glad that you posted it. Thanks for the info...
Also, we used curry combs to scrape our foam down. They weren't expensive (from TSC), and they didn't have the health risk that John mentioned, since they were bigger chunks, scraped off and the particles didn't get airborne.
Merry Christmas,
God bless,
NewbeeMC9
This is my post from the tiger foam post
I used these on a room in my house due to limited acces of MBOB (my big o butt )
http://www.sprayfoamdirect.com/products/index.php?page=shop.browse&category_id=6&option=com_virtuemart&vmcchk=1&Itemid=1
I also wanted Closed Cell Foam, for the better sealing and higher R-value so make sure of what your getting.  Open cell has half the r-value and can let moisture through, but it is still better than nothing or fiberglass etc.
the guns get pricy and break easily.
the tanks covered more than estimated, and i foamed the door to my bus while I was at it.
If i had to do it again, or if i do some more and other things,  I was strongly considering this gun, but you need a good compressor,
http://www.soythane.com/?q=node/5
once you have the gun you can spray the other products from Spraymax like bedliner and garage floor coatings, or foam other smaller areas, options are open.
HTH
oh yeah, the people here were quoting some high prices(3-5$/ft sq) so i did some of the job myself
also,
While you have the floor up and cleaning.  I would consider how you can use that space, fresh water tanK maybe,  seems wasted on my MC9, tank might give you some thermal mass if you need it in the right spot.  also if you coud put a hatch in the center aisle you can put a lot of stuff there and have access to upgrade later as you learn and change your mind.  also i have a positve pressure there going down the road.  which causes a lot of AC loss(heat gain).
i vote sandwich flat sheets in the floor just for ease of installation.
but most of all,
do it your way. ;D
JohnEd
NewB,
I note this place is touting their "GREENESS" and lack of bad stuff.  Did you have a fresh air issue?
Hot foam has an R value of 7.5.  One product on that site is spec'd at 7.0 and another at 7.7.  A 150F degree temp limit doesn't seem adequate.  Did I miss something?
I think if I had an entire house to do I would use that stuff and especially if a garage was also in the mix.  Thanks for the post and link.
NewbeeMC9
JohnEd,
I did a room that had been taken in from a carport and had no insulation in the attic or under the floor and has a low pitch roof.  The spray foam quotes i was getting were high I thought I would try the Foamit Green myself on this room and learn from it. Some areas i just sprayed at and wish the gun could have been longer.  I didn't have air problems doing the attic but i kept the pretty good fans going yjere was more ventilation and i sprayed slower.  I only had the one fan going when i was underneath and had trouble if i got out of the direct line of the fan.  I was moving faster and spraying more underneath too.
major improvement on the, room not too uncomfotable with the vents closed, will prolly come back over with loose fill in attic for more r-value.
they released the Spraymax after i had purchased the other.  I am wanting to do the rest of my house, and build a building and insulate it and maybe coat the concrete as well, so the spraymax was interesting me due to the smaller volumes to spray. and the gun investment might be worth it with a lot to do.
PS note that i did not use the quote featue and just addressed the poster :D
JohnEd
Newbee,
You ad new dimension to the term "Iron Lung". ::)  Nice results though. ;D
circusboy90210
could this foam be sprayed on a mesh two buildaboat?
It's all fun and games til someone gets hurt. Wink yeah then it's really hilarious 8)
NewbeeMC9
Quote from: circusboy90210 on December 25, 2008, 11:43:01 PM
look for the denser stuff, i think that's what the use in boat building
Quote from: JohnEd on December 25, 2008, 09:25:40 PM
Newbee,
I think the R-134 gave me the most trouble when i was laying down and spraying up,  if i moved from in front of the fan it was rough,  only did that once. :P
