50-AMP
Started by Ednj, June 11, 2008, 04:24:15 AM
Ncbob
Guess it's my turn again, Ed. Not knowing if your generator has a belt driven alternator or uses a charge winding in the generator end I really can't totally answer that aspect of your query.
As far as the Inverter is concerned when it sees 120VAC it is only trying to do its' job and that is to charge your lighting batteries. It doesn't know about another charging source or, from the info given, does it care.
Pretty much the same for the generator although if the gen/set charges from a battery charge winding it should be the weaker of the two and, not having a voltage regulator as an alternator would, should acquiesce to the greater charge rate.
A solution? The reason your ammeter (or voltmeter) is dancing around is because it has too many masters....
conflicting charge rates. You might consider switching the field circuit on your belt driven generator alternator which would take that charge source out of the equation when you need it to be so.
If I might add any further confusion to an otherwise interesting topic please let me know.
WTIC (with tongue in cheek)
Bob
Ednj
Quote from: NCbob on June 11, 2008, 02:29:47 PM
Bob
Thanks Bob,
I might just make 500 posts today.
I have a Magnum 4024 inverter, a Onan 7500 quiet diesel generator and NON belt alternator on bus engine.
I think I can shut off the charger at the inverter control panel in the future. :o
MCI-9
Sussex county, Delaware.
