Wheel Bearings
Wheel Bearings
Started by PlumCrazy, May 27, 2008, 04:38:42 PM
PlumCrazy
Does anyone have part numbers for inner and outer front bearings and races and inner oil seal for a GMC 5307 (1982) Fishbowl?
I would like to order them in advance before I tear it apart.
I have the maintenance manual, but it does not list part numbers.
Mike.
1982 GMC T6H-5307
tekebird
sorry don;t have them for you.
if you call Luke at US COach he will be able to look them up and get them for you.
I might suggest you buy the other BOOK for your bus the parts book, it is as good as a reference as the maint manual as it is filled with exploded views of assemblies
Paso One
Hi Mike  When I go to the shop I have a set of inner and outer bearings from a 77 5307 (parts bus) that I could give you the bearing # that you could cross reference locally.  The seal #  is not handy but I'll see if I can dig it up .
P
PlumCrazy
Thanks Paso, that would be great.
I'd hate to bother Luke at work when I'd be buying the bearings locally here in Canada.
1982 GMC T6H-5307
Paso One
I could only get the outer #'s as the inners are left in the hub at a differant location   Timpkin # 557-S
Sojourner
NAPA have heavy truck & bus parts. They may already have parts number there. Call them or wait until you have them out to bring or write the number. They will get for you. They deal with class 8 truck & bus mechanic & repair shops.
I wouldn't order before inspection so you won't get the wrong parts or something difference than OEM.
Again...you may end up waiting for extra parts which it can be order the first time but you didn't know.
FWIW
Sojourn for Christ, Jerry
PlumCrazy
Thanks guys.
I'll tear it apart and double check all numbers then order.
1982 GMC T6H-5307
lesrMC9
as a trucker [with a T ] and a busnut, take all parts with you when buying, it saves the parts guys a lot of trouble!
and do not let them sell you National seals.
I did a brake job on my truck in Feb. and have now changed/replaced all NATIONAL seals because of failure-- one at a time what a pain in the butt!!
I would suggest  CR  brand of seal
also if you are near big truck dealerships [Freightliner-Mack-Peterbilt-Volvo-International ]check their parts dept. for pricing -- in my area they are much cheaper than NAPA or any other parts specific stores
Les R MC-9
ps where in Canada are you -- Langley, BC for me
Big Transit here in Toronto still running GM New Looks.
MCI and Prevost both support these transit parts.
