weight of a 4104 shell guess correctly and win a prize
Started by 4104bigred, June 04, 2006, 08:24:55 PM
Len Silva
If you can, disconnect the cable in front and pull it all the way out. I't nice if you have a clean tubĀ  or bucket of some kind to coil it up in.
Flush the tube out with WD40, kerosene, diesel ect. and blow it out with compressed air.
Clean the cable and lube with a light grease (I like the white lithium in a spray can) and insert it back into the tube.
Make sure when you hook everything up again that you can get full throttle at the governor.
Good luck,
Len Silva
4104bigred
