Kneeling rookie question
Started by skipn, April 21, 2008, 01:53:26 PM
skipn
JR,
   Solid sound advice
  thank you
   Looks like I'll be saving up my money....:)
Skip
JohnEd
Air down the bags AND the tires  4 inches and you have it....I think.  $500 for an adj sus height from the driver sounds like the way to go.
I would not leave the tires aired down but wuld air them back up once inside.
My 2 centavos,
Fredward
Whats Pete's campground level kit? I did a search but nothing came up.
Fred Thomson
NJT5047
Pete's offering a module (all wired and plumbed) that has electric air valves that will operate, or allow the driver to control from the dash,  one air bag assembly.  Use three for most MCIs...or one for each leveling valve.
Believe he's offering a control panel that's all done up and looks nice.
The setup uses the OEM airbags for levelers.  It'll give about 6" side-to-side, and 6" front to rear...depending on how much you'll over pressurize your airbags.  There's a little more lift at higher pressures.   Letting most of the air out on one side and inflating the other gives a good bit of leveling capacity.
This device doesn't work well on Eagles.
Create a new topic directed at him for information in the subject line and he'll describe his system.
JR
JR Lynch , Charlotte, NC
Ayn Rand
DrivingMissLazy
Quote from: Fredward on April 22, 2008, 07:36:10 PM
Here is his address and email information. He is generally on the board every day.
  Summary - RTS/Daytona     Picture/Text
Posts:    226 (0.298 per day)
Position:    Full Member
Date Registered:    March 25, 2006, 06:07:13 PM
Last Active:    Today at 07:30:52 AM
ICQ:
AIM:
MSN:
YIM:
Email:    hawk_ii_mail@yahoo.com
Website:    BUS CONVERSION PARTS FOR SALE / PROJECTS
Current Status:    Offline Offline
Gender:    Male
Age:    N/A
Local Time:    April 23, 2008, 08:18:39 AM
Language:
Signature:
