Anyone Know Alcoa #'s
Started by Paso One, September 27, 2006, 06:46:18 PM
Len Silva
I'm wondering if it's possible to modify a hub piloted wheel which is now much more common and available than stud piloted. Assuming the stud diameter and bolt circle are the same, could the stud holes be champhered and the hub bore resized?
Len
Dallas
Quote from: Len Silva on September 28, 2006, 09:29:55 AM
Len
Len,
I don't think there is.
Stud piloted wheels are mostly SAE (inch) and Hub piloted are mostly Metric.
You may be able to go to your local bearing and wheel place and see if there is a hub that will interchange with your spindle. Or you could go deeper and see if there is a Kingpin/spindle setup that will interchange close enough to make work.
Good luck, no matter what you do.
Also, if you find changeovers, let us know!
Dallas
Len Silva
Looking at the Alcoa website above, these are the measurements for both type wheels
                                  Bolt Circle          Hub Bore       Bolt Hole
Stud Pilot 883110DB     11.25 "              8.73"            1.219"
Hub Pilot  885600DB      285.75 mm        220.1 mm      26.75mm
                                  exactly the         0.065"           0.166"
                                   same                smaller            smaller
I don't know the chamfer angle on the stud holes but it looks like a competent machine shop could modify hub piloted wheels to go on stud pilot wheels without much difficulty.  All the other dimensions are exactly the same.
This is not something I'm considering for myself, just tossing it out for discussion.  It looks like used take off hub piloted wheels are much more readily available.
Len
Paso One
I will pull the nut off the wheel with the washer on the nut to see if the nut is also champhered it is possible its got some kind of odd ball nut and washer.  My bus and my parts bus were both made in Canada.  Brians old bus was made in the USA that is the one with the nut with washer style nuts.  On the link wayne posted it shows a 10 hole hub piloted bus mounting column (line 15 & 16 ) that uses the two piece flange nut. But I think I got my answer I'll watch for stud located aluminum wheels on the e place. What started this is someone in Canada had a set with no Bids. Thought I'd look to the future. :0
n4rsn
The wheels with the washers behind the nut, is called Hub-pilot.
The wheels with the nut chaffered, actually centers the wheel, is called a, BUDD wheel.
Just so you know
Steve
Hello tire changers.
Budd wheels are a popular name for the stud pilot style, with chamferred edges to the holes and fasteners.
Hub pilot use the fasteners with the integrated washer on the nut and have squared off stud holes on the wheels. In the past I have heard them called "motor wheels" and recently some trucking media call them "transit wheels" because they have been very popular with the bus folks for a long time.
You may successfully use a stud pilioted wheel in a hub pilot system, since the chamferred edges are irrelevent, but you may not switch the other way. Square edges on stud holes are not compatible with the chamferred fasteners.
