oil leak
Started by robert, April 18, 2008, 10:28:35 AM
robert
Hello all,
I have a 6v92 with an oil leak on the bottom side of the turbo. The oil supply line and oil line are clean. My question is how hard is it to change that gasket and do you have any hints. I will be starting this around 2:00pm today because the wife has a show tonight.
Robert
Thanks, Robert at www.tamihall.com
Its a simple repair just 2 bolts with 3/8 head but fwiw every time I thought it was the gasket it turned out to be the pipe broke at the flange still a easy fix   one other thing I found the gasket making silicones will not work for me always had to buy a new gasket    good luck
