MCI 7 CONDENSER BAY
Started by Stormcloud, February 25, 2008, 07:56:52 PM
Stormcloud
I will be removing the OTR air conditioning and replacing it with a ductless split system; I would like to install the condenser in the empty MCI 7 condenser bay, but the height of the bay is only ~28". The baggage bay beside has an interior height of ~34", so there is something above the condenser bay (maybe a duct) that I would like to remove.
This has probably been done many times before, but I want to know what I'm in for before I start.
Comments?
Thanks.
Mark
Mark Morgan
1972 MCI-7 'Papabus'
8v71N MT654 Automatic
Tony LEE
If you take out the entrance ramp you will be able to see what is in that area.
JackConrad
On our MC-8, that space was a void filled with fiberglass insulation. We installed louvers in the exterior skin above the condenser compartment, added a couple baffles in the void and cut an opening in the floor of that space. This is the air intake for our generator (installed in OEM condenser bay). If I recall correctly, there was a steel framing member in that area.  Jack
Tenor
Great post Mark!  I also have an MCI 7 and I thought the floor was all that was up there!  I went out in the snow to check, and I suspect Jack is right and we have the same thing there for heat protection and sound deadening.
Glenn Williams
Lansing, MI
www.tenorclock@gmail.com
2001 MCI D4500
Series 60 Detroit Diesel
4 speed Spicer
Stormcloud
Jack:
Thanks for the insight.
Assuming I can cut away everything above the factory condenser area up to the floorboard, I can place the ductless condenser in this preferred location. We'll see if the structural member is going to interfere or can be removed without causing grief.
Best regards.
Mark
Mark Morgan
