Which way does a bus engine turn
Started by Duallydude, December 10, 2007, 03:50:46 PM
Duallydude
Ok a diesel mechanic Im not and this is the situation..In the last 30 days I have aquired 3 Eagle buses..a 1957,1985 and a 1986..Well the 85 runs great but the 86 doesnt have a engine..What type of 8v92 do I need to go in it?..I was told a over the road engine like in a KW or Pete turns one way and a bus engine turns the other..Is the a letter that goes behind the engine model to tell me if it turns left or right and which way does a bus engine turn..I have a good mechanic but I dont want to approach him and ask this and look like a fool
Don Fairchild
Your eagle is a t-drive and uses a right hand rotation engine and a truck engine will go into it just fine. The gmc and rts buses used a left hand rotation engine. They will not work in your eagle.
Hope this helps
Don
Duallydude
THANK YOU..Very much..I knew in the back of my mind that some engines went one way and others the other..I just wasnt sure which did what..Again thanks so much..See a old dog can learn new tricks
rcbishop
Mine always turned with the coach................ ;D 8) ::) >:(.
Sorry...couldn't resist .
RCB :-\
