now This looks like a REAL Honey..
Started by superpickle, November 14, 2007, 04:26:37 PM
brojcol
QuoteIn Low, Low, Low, Reverse (Which was the only forward gear in the back transmission), at 2100 rpm on the old cummins 180 engine, You could put the truck against a Lodge Pole Pine and walk away from it for an hour. When you came back the truck would be buried to the axles or the tree would be knocked over.
When I was growin' up, out in the log woods, they called that low gear, "grandma"
"PUT 'ER IN GRANDMA AND GIT ON OUT FROM HEAH (HERE)!"
"Ask yourself this question...Are you funky enough to be a globetrotter?  Well are you???  ARE YOU?!?!
deal with it."            Professor Bubblegum Tate
