neutral safety switch v730 removing
Started by johnjem, September 27, 2007, 04:47:50 PM
johnjem
Has anybody removed 1 of these from the side of the tranny v730 allsonI am going to take it out and put it on the tranny i am installed in my bus that does not have 1 on the new tranny,is it basic off and on or will the tranny fall apart when i take it out??lol//??or should i just bypass the whole switch?? i have it i might as well use it right?
Never stop thinking,it"s what keeps us going till tomorrow
http://photobucket.com/johnsgmc4905
Sammy
It unscrews from trans, no big deal. I have the special socket for this task - Kent moore tool.
It can be done with a wrench, might have to buy a cheapo and grind it a bit, lose a little fluid during removal.
Good luck.  8)
donnreeves
The neutral safty switch is on the back of the trans below the yoke. The one on the sidw is for back-up lights. Donn
johnjem
thanks guys so i just unscrew it right thanks  sammy
Sammy
The RTS" I wrenched on with 6V92TA's and V730's had the neutral safety switch threaded into the trans just above the shift linkage lever. 2  plugs on valve body by output flange were main pressure and reverse.
Hope this might help.  8)
