Plumbing Questions
Started by buddydawg, September 10, 2007, 10:06:42 AM
buddydawg
Thanks for the input Mike, it is always nice to hear from those brave enough to convert a fishy!  I am definitely in favor of installing a working system that can be upgraded in the future.  I am all in favor of using the bus while it is being converted.  That is what keeps me motivated!  I haven't scrapped the OTR Heat & A/C yet but it is on my list of to dos.
Tom, thanks for your input as always.  I am still considering a setup similar to yours with the raised bedroom in the rear with the tank over the axle.   It would be an efficient use of space that is fairly easy to access for water pumps, heaters, etc...
I am going to use PEX, I have just never used it before.  Doesn't look very complex and they are using it in most of the new houses I work in.
1972 GMC T6H-5308A #024
1984 Eagle Model 10
Brandon Stewart - Martinez, GA
kd5kfl
A lesson learned in a sticks and staples motorhome:
My '73 Pace Arrow had a 20 gallon freshwater tank. And a 10 gallon greywater tank. Don't do this. Make the greywater tank 20% bigger than the freshwater tank.
