mc9 cooling system
mc9 cooling system
Started by ttomas, June 21, 2007, 08:53:41 AM
ttomas
Are there any alternatives to the dual squirrel cage radiator system? Mine throws alot of oil and I thought it may be just as well to change the system. Thanks Tom
gumpy
Not unless you brew something up yourself.
You'd probably be best to pull the assembly and rebuild the gearbox. New seals, etc.
craig
Hi Tom,
It may be easier to fix the oil leaks??  ;D ;D
Good Luck
Tom -
MCI built over 9,000 MC-9s with that cooling system.
It may be marginal on hot days climbing Rocky Top out west, but it works.
Clean it up and fix it up RIGHT and you won't have to worry about it.
If you don't already have one, get a shop manual and parts book, well worth the $$$.
