Repair for regulator
Started by James77MCI8, May 16, 2007, 03:34:17 AM
James77MCI8
Hi guys,
THe regulator for the tensioner on the cooling fans on my bus is leaking. Do you all know where to find a replacement and or repair kit for this device?
       THanks
77 MCI 8
8V-71 4 spd
Sojourner
Take your regulator to your local heavy truck parts place & show them your needs.....usually diaphragm is leaking & common size fit most units.
Perhaps nowadays it only available in exchange format. No repair kit???
PS....Caution do not use Teflon tape on threads but use pipe dope paste with Teflon or without so you won't over tighten into die-cast housing. Reason for not to use tape is small pieces get into valve-ling to cause leakage...very common problem.
FWIW
Sojourn for Christ, Jerry
LUKE at US COACH
Hi James and Folks:
The repair kit is a stock item for us.  You can call us toll free tomorrow at: 1-888-262-2434.
I Hope this HELPS!!!
Happy & SAFE!!! Bussin' to ALl.
LUKE at US COACH
James77MCI8
Thanks Luke! I will Call you
77 MCI 8
8V-71 4 spd
