6v92t not building oil pressure
Started by brettpearson67, April 13, 2019, 10:57:07 AM
daddysgirl
Quote from: brettpearson67 on April 21, 2019, 05:20:14 AM
There was debris, but it appeared to be silicone sealant from the pan(no gasket). Did not see metal. When I get it home next weekend I will cut the filter apart and see what I can find.
There was, however, a small amount (drops) of coolant in the bottom of the pan. That concerns me, for sure.
This is one of my weaker subjects, so let me know if I am wrong please...
Is there any chance a piece of silicone got up into one of the lines, causing the jumping pressure?
As for the bypass valve...I was thinking of the valve that is in the inlet passage of the oil cooler adapter? I believe that is the valve that kicks in if the cooler is plugged?
Andrea   Richmond, VA
I believe he has a electrical problem in the shutdown system it resets while he is changing the filter ,the filter getting plugged is another subject it may have the wrong filter you can run 1 without a filter with plugging the lines if he has a remote mount filter
daddysgirl
Quote from: luvrbus on April 29, 2019, 07:44:00 AM
If it's electrical, can he isolate and disconnect the low oil pressure circuit just long enough to see if that is the issue? Or would that be too dangerous to the engine if both gauges are reading properly?
Andrea   Richmond, VA
