Leveling jacks
Started by Jim Blackwood, March 13, 2019, 08:47:03 AM
uncle ned
HUGGY has hydraulic leveling jacks also.  I use the air leveling to get her level and than use the Hydraulic to steady her, to keep her from rocking.
The air is Level It from some guy that has been gone for a while. The hydraulic has four levers that control the jacks.
It has one pump under the drivers seat in the steering compartment.
I can lift one wheel off the ground but have to lower the opposite corner.
Had a blow out on I85 south due to a tree blowing down in front of Huggy.
When the tire changing truck came along he did not have a jack to go under the axle and I had to pick up with the jacks to let him get his jack under.
You can never know what is going to happen with a old coach.
uncle ned
4104's forever
6v92 v730
Huggy Bear
