4501 Cooling fan damper
Started by tuccitown, October 09, 2018, 11:04:56 AM
tuccitown
Hi All,
I am currently looking for the part number and or source for the cooling fan damper for a 4501.
During maintanence I found that it has some chunks missing, still seems pretty solid but would like to get it replaced before to long.
Any leads or ideas?
Thanks in advance,
Jack
1979 GMC H8H649-053 Conversion in progress.
1955 GM PD 4501-377 Converted.
You can check with Luke. He may have an idea where to find one or get that one repaired.
If no luck there maybe you can remove damper and go with an equivalent fiberglass fan.
You have photos are we talking about the Morse coupling ?
tuccitown
The front looks good the back is where it looks to have started to fail. I found it because I was checking the oil in the fan drive as you can see it seems to have started to leak.
Jack
kyle4501
Didn't some prevost have a gearbox driven fan for a side radiator?
I'm thinking it might be easier to find one of those fan and hub assembly & adapt it to fit your gearbox.
Quote from: kyle4501 on October 10, 2018, 06:52:59 PM
yes Prevost did and some Eagle did
tuccitown
Just completed a 524 mile round trip without issues. Fan damper seems tight even with the fore mention visual issue. May be a non issue but will keep an eye on it for sure. I made a breather for the fill plug and now the fan drive used no oil on this trip.
The last trip was in the 90's so may have had something to do with the oil use with no breather on the gearbox.
Thanks for the suggestions,
