Bus Nuts Locations Worldwide
Started by Gary Hatt - Publisher BCM, October 12, 2018, 04:42:41 PM
You can now locate your Bus Nut friends on a map thanks to Neil Fluit of Phoenix Coach.  To see the map, go to our Home page at https://www.busconversionmagazine.com/ and click on the Cool Stuff tab then Bus Nuts Locations Worldwide.
Scroll down a bit and you can add your name and info to the database and after it is reviewed, you too will be added to the map. It is nice to know where people are near where you are, or may be in the future, in case you need help.  It is also nice to know that you may be able to help another Bus Nut sometime in the future.
Check it out now and add your name to the database.
1999 Prevost H3-45
