battery choice for house? - Page 2
Started by John Z, January 29, 2007, 08:09:23 PM
pvcces
John Z, if you really want to get some satisfaction out of your house batteries, be sure to buy and install a DC power meter.
They aren't cheap, but they take the guesswork out of your setup; you can tell when you've discharged the batteries to a given level or if one of them is going bad. There's no substitute!
Good luck with your house system.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Linda-XL40-FL
This has nothing to do with batteries --- I couldn't help but notice John Z's bus serial number (PD-4104 1439).  Mine is PD-4104 1438, so our buses probably came out of the plant on the same day.  Small world.
As for batteries, I'm using eight 6-volt AGMs by C&D Technologies.  Their web site is interesting -- www.cdtechno.com -- these batteries are normally used for standby power systems.  So far, so good.
Kirby
John Z
For the time being while i look around for a DC power meter or a good deal on an inverter, i took the low buck approach and wired in a digital voltage meter to read either the bus start batteries, or my coach/house batteries.
To how low of a voltage can the batteries be taken before they should be recharged? It seems i read that you should not take them any lower than 12.00 volts, but i am not sure. What do you guys recommend?
Kirby, i think i have seen your web site, on your repower etc. It was impressive!
www.silverbrook-mn.com
kyle4501
There is a nice chart in the Phred's Poop Sheets link . . .
BATTERIES--AND OTHER ELECTRIC STUFF
phred Tinseth © 1999-2002 Reproduction permitted
Web site:  http://www.phrannie.org
