Confusion with voltage regulator
Started by Fred Mc, September 30, 2017, 03:14:05 PM
Fred Mc
I am attempting to change the wiring in my GMPD4106  to eliminate the Regulator sensing relay.
The Voltage Regulator quit a couple of weeks ago so I got a replacement IC  board from Luke. When I put the "new" voltage regulator in it still didn't work until I ran a HOT wire to the positive terminal of the VR. Now that I have the VR out as well as the sensing relay out I am somewhat confused on the wiring terminals on the VR.
In the bus manual the VR diagram shows 3 terminals-POS, FIELD and SWITCH with the case being grounded.
However in the instruction I am using to replace the relay the diagram shows POS, FIELD and NEG(ground). And when I check the VR with a meter it shows that the terminal marked SWITCH on the VR is grounded.
Is the Delco Remay VR grounded through the case or via a terminal and ground wire?
Fred
MrCrowley
Quote from: Fred Mc on September 30, 2017, 03:14:05 PM
Fred
Ok all's a relay is a switch so you can energize higher voltage equipment ( starter,high amp blower so on ) .a voltage regulator keeps voltage at same level as not to apply to much voltage this is a regulator general diagram
data:image/jpeg;base64,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
