Fluids
Started by Billysurf, August 28, 2017, 08:39:35 AM
Billysurf
Oil is dead center between L and F, need to top off yet?  Had an oil change in April.  And a regular SAE 40 like I'd buy at Advance Auto etc.?
Also, coolant looks full, am I reading this right?
1988 MCI 102A2 Richmond,VA http://martinsgonemad.com
No need to top off the oil. Wait till it is at the fill (add 1 gallon) or a bit lower. Typically your oil has to be 4 gallons low before your engine will be starved. Good Luck, TomC
Billysurf
Quote from: TomC on August 28, 2017, 09:21:52 AM
Thanks!!!!
