Studs for Aluminum Rims
Started by brianzero, August 15, 2017, 07:13:05 PM
brianzero
Does anyone have a source or part number for extended studs for aluminum rims (MCI-9)?
I got tired of chasing the studs and numbers so I purchased mine from Luke 1-856-794-3104 they are not cheap fwiw ,Luke had a way lot better price than MCI
lostagain
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
Quote from: luvrbus on August 15, 2017, 08:36:17 PMI got tired of chasing the studs and numbers so I purchased mine from Luke 1-856-794-3104 they are not cheap fwiw ,Luke had a way lot better price than MCI
        My new axles (brakes, steering, bearings, etc.) are Meritor and they come with matching alu wheels so there's no issue of buying a full set for me, but I was wondering -- short of absolute destructive/overtorque handling, are studs and nuts a "maintenance item; i.e., do you expect to have to replace them on any kind of a repair basis?
brianzero
Luke has those studs, and its gonna be $161 per side. Roughly $16 per stud.
lostagain
Bruce, studs and nuts should last a long time, unless they get abused and over torqued by an overzealous tire guy with a 1" air gun that will stretch them.
JC
JC
Blackie AB
Quote from: brianzero on August 16, 2017, 09:07:53 AM
Yep and the studs come just the stud no inside the drum nuts or lock washers or the wheel clamping nuts makes you wonder if it is worth the price for wheels you polish all the time
Quote from: lostagain on August 16, 2017, 09:30:14 AMBruce, studs and nuts should last a long time, unless they get abused and over torqued by an overzealous tire guy with a 1" air gun that will stretch them.   JC
Quote from: luvrbus on August 16, 2017, 10:33:05 AMYep and the studs come just the stud no inside the drum nuts or lock washers or the wheel clamping nuts makes you wonder if it is worth the price for wheels you polish all the time
       Thanks, JC, that's kinda what I thought but the studs stock on my bus had a torque value of 250 pounds (???).  You might not know that I'm updating to a set of modern Meritor axles from a Gillig lo-floor so the package comes with alu wheels so that I'll be dealing with a different set of parameters in the future.
        Appreciate that info, Clifford.  I got a set of manuals with the Gillig/donor bus and I'll have to check that out -- the design on the Meritors is completely different from what I've known before - the English studs are pressed in from the back.
        Thanks, this discussion is helping me understand what I need to know about my new components.
