Generator lifespan
Generator lifespan
Started by windtrader, May 04, 2017, 02:49:22 PM
windtrader
Always wondered how long gensets last. Here's one with more hours than any bus conversion will likely see.
"Onan Marquis "Gold" 7000 gasoline generator rated at 7 kilowatts -generator has 35218 hours"
Interesting coach for a conversion too.
https://losangeles.craigslist.org/lgb/rvs/6117059958.html
Don F
1976 MCI/TMC MC-8 #1286
Fully converted
Bought 2017
That will read 3521.8 a Onan Marquis hr meter will only read 9999.9 then it resets back to 0 fwiw
windtrader
Quote from: luvrbus on May 04, 2017, 03:20:46 PM
Ah. Thanks! 30k hours did seem very impressive. LOL
Don F
Fully converted
Bought 2017
Geoff
That is still a lot of hours for a small gas engine.  I always think of 200 hours as equivalent to 10,000 miles. I got 176,050.0 miles from 3520 hours.  That engine, if it is the original, should be put in a museum.  Or someone left the key on quite often and the hour meter ran without the engine running.  Who knows....
--Geoff
Geoff
'82 RTS AZ
My first Onan Emerald III 6.5kw gasoline on my truck ran over 12,000 hours before it spun a bearing. The old design of opposed 2 cylinder 1800rpm. Always had a 1,500 watt load on it (block heater) so never had the heads off for de carboning. Still would never have another gasoline generator again. Good Luck, TomC
I see a lot of Onan gas and propane generators with 5 to 7k hrs and never had any problems
somewhereinusa
I've had two Onan quiet diesels that died with less than 1000 hours. Both threw a piece off of the generator rotor. It costs more to fix them than they are worth. >:(
1991 Bluebird AARE
1999 Ford Ranger
Andrews,IN
