Weld On Exhaust Connector
Started by luvrbus, March 18, 2017, 01:37:34 PM
I need to know where to buy a 7 inch flared connector to weld on 4106 muffler any ideas
thanks
Jim Eh.
Are you looking for a 7" OD-ID connector?
Try:
Dynaflex) http://www.dynaflexproducts.com/media.php#catalogs
or GrandRock) http://www.grpipes.com/onlinecatalogs.asp
or Lincoln Chrome) http://lincolnchrome.com/
Here's one but don't know anything about them (other than being a little pricey) http://www.truckpipestore.com/7-connector-id-od-aluminum
Other option is if you can find a 16 ga tube to cut a slice (or two or three) out of to make an ID or OD connector of your choice since this is probably a one off.
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
OneLapper
Quote from: luvrbus on March 18, 2017, 01:37:34 PM
thanks
I had to have one made for me a shop.  I never found one commercially.
OneLapper
1964 PD4106-2853
www.markdavia.com
Utahclaimjumper
 If you need the flare for the V band connection at the bottom you will probably have to have one formed.>>>Dan
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
I'd go talk to a metal fabrication/machine shop. Shouldn't be any problem for a larger one. I'd swear our local one could build a battleship if they received an order for one. I've seen them make some incredible items. They made my 4104 aux fuel tank replacement, and a replacement coal furnace kidney that bolted right up to the flange and support without any filing or prying to attach it.
