SOLVED! Broke down New Mexico
Started by Scott & Heather, October 25, 2016, 02:20:39 PM
If you get that Silverleaf you talked about it should be able to display codes.  I don't know if it will actually flash or something if you get a code set.  My lights work so I just check the log on the Silverleaf if my light comes on.
The SilverLeaf and the lights are good to show and  flash the codes but you still need DDC software on a lap top or a Pro/link to delete the codes
And remember,
The silver leaf taps into the DDR plug wires so if the check engine signal (419) isn't getting up there, silver leaf isn't going to read any check engine codes.
thomasinnv
Scott do you have a cel in the front driver side bay hvac junction box? I was able to retrieve codes that way when my dash cel bulb was burned out.
Sent from my SM-G920T using Tapatalk
1998 MCI 102-DL3
Series 60 12.7/Alison B500
No hvac junction box. It's a generator bay now :)
blue_goose
way back I posted about looking at the check engine and stop engine lights.  That is the first thing to check if the engine doesn't start.  You had said the lights might have been changed..  I checked mine and the check engine is the second from left at bottom row and the stop engine is the third on same row.  If they don't come on start with the power to the ECM.
Sure glad it is going now.  I have been gone to a rally and just got back.  That was good news.
Jack
Thanks Jack! I'll have plenty of other stories in the future :)
