help with a route
Started by David Anderson, June 14, 2016, 06:55:57 PM
Dave5Cs
Agree with Lin and Ed H. 40 to 58 over Tehachapies and down through Bakersfield onto 99 south to exit hyway 119 the pumpkin center or Taft west and your home free from there.
Dave
David Anderson
I drove 600 miles and made it to Las Cruces NM today.  It got to 104 on the thermometer.  195 max on the water temp but my oil temp is going to 240 and above in a hard pull.  Should I be concerned?  I'm keeping the rpms up, but it doesn't help. It was 111 there today.  Even my genny climbed to 195.  The coach was nice and cool however.  I checked my oil level after we stopped for the night.  It didn't use any in 600 miles.  I'm driving to Tuscon tomorrow morning, so temps before noon will be cool.  We will head to Phoenix from there after 7:00pm, so it should be ok, too.  The real test will come Sunday when I drive from Flagstaff to Bakersfield.  Could be dicey.
David
David, you are good to 250* oil temperature and won't hurt the engine for short periods over 250*,generators with the 6v92 run about 200* to 240*all day long for years
thomasinnv
What is an acceptable delta for the coolant to oil temp on a detroit? I know on my PSD anything over 25 deg is cause for alarm and start looking at replacement oil cooler.
1998 MCI 102-DL3
Series 60 12.7/Alison B500
195* water temp on a 11.1 /235* oil temperature
