Squirrel Cage fan drive pulley broke
Started by Fredward, December 11, 2015, 03:54:46 PM
Fredward
Squirrel cage fans for engine radiators on the MC-5. I'm putting new seals in the gear box but broke the drive pulley trying to remove it. Where do I find a new pulley? Its a variable speed drive pully by the looks of it. ??
Fred Thomson
lostagain
A good welder can fix it.
Try Luke for a used one.
JC
JC
Blackie AB
1977 MC5C, 6V92/HT740 (sold)
You can buy the pulley from MSC Direct or just replace it with a standard like MCI did
edvanland
I think I still have the original one off my 8v92 I went to the smaller one, if that will work for you let me know and you can have it just pay shipping.
let me know
Ed Van
MCI 7
Cornville, AZ
Is the id or shaft diameter on the 92 the same?
They used the same mitre box just larger fans
Fredward
Yah good point, we can probably weld it. Ed I may take you up on that offer; I'll do a little more research.
What is the purpose of that pulley, is it supposed to be a variable speed sheave? If you open it up you speed up the fans?
Fred Thomson
gumpy
I think I still have the one off my MC9. It's not made like yours. One piece. It might fit your shaft.
If you weld it, you'll probably need to machine it and have it balanced.
It's really a tension pulley on the old model 5's to keep the belt tight,most MCI with the air cylinder didn't use that pulley get Gumpy's pulley it will work
gumpy
I just checked the garage. It's here if you want it.
Brett G
Along the same lines...How would I go about acquiring the smaller pulley that everyone talks about for my MC7?  Thanks
Brett
1970 MCI MC7 Challenger
8v71 / HT70 Allison
Goodhue MN
Our Bus http://goo.gl/zmk9M9
Fredward
I got the gear box back from C&J bus and Steve gave me a box of parts to fix the pulley. So I'll be good to go.  Thanks for the offers guys.
Fred
Fred Thomson
