VOTE! Carbunkle choices for MC9
Started by ChuckMC9, January 10, 2007, 08:49:05 AM
Knowing what you know, which of these options would you now choose?
(2) Penguin 13.5K Heat Pumps
0 (0%)
(1) Carrier AirV 13.5 Lo-Profile Heat Pump + (1) AirV 15K Heat Pump
2 (66.7%)
Other
1 (33.3%)
Total Members Voted: 3
ChuckMC9
Open floor plan, +- 30' of open space.
NON-ducted.
95% southwest travel. If I spend anytime in freezing temps, I'm doing something wrong! :)
Current understandings:
- Dometic's warranty is better, 3yr vs. 2yr.
- Dometics have three speed fans
- Carrier's large unit has better CFM than Penguins - (365 vs 335...important?)
- Carrier's amp draw is an amp or so less, even the large unit compared to the Penguins
Confusions:
- Blower off when compressor off?
- EMS connectivity / external compressor control possible?
- Remote thermostat possible?
Getting this info from the web has been quite a frustration, and the couple of dealers I've talked to weren't any help.
After looking at the schematics, it appears that it's more straightforward to connect external controls to the Dometics, but I don't have any definitive proof of that.
What I'd like to do is use the manual units, then add external controls later when I get fancy.
Does anyone have any better information than the web sites of both Dometic and Carrier?
Many thanks!
-Chuck
