How to remove air wiper motors
Started by Scott & Heather, August 24, 2015, 04:49:59 PM
I'm still waiting for my rebuild kit to arrive from Luke. Once it comes I'll be carefully rebuilding. I'll let you know how it goes Dave. I sure hope I don't end up with dead wipers
BeastMaster
I rebuilt both of mine. Used pipe wrench on outside nuts. Take your time, test fit the pieces, try it mechanically prior to air valve.  Then be careful, slip in the air valve, the bench test.  Take pictures as you take it apart.  Good luck.
Allan
Sent from my SM-N910T using Tapatalk
1989 - MCI 102C3 8V92TA T740
Converted by Dick Lamb, Custom Land Yachts - 2005
Famous Margaritaville Bus
Star of the Duncan Family Counting FireFlies
Well, Christmas came for me today! I'll be working on this tomorrow. Wish me luck. I'll take your advice and take plenty of pictures
Seangie
Scott -  let me know how it turns out.  Ill do mine in Texas in February 8)
'Cause you know we,
Driving through the night
To that old promised land'
I accidentally posted this in Dave's thread...I meant to put it in mine.  ::)
Ok. In Dave's defense, (Tikvah), I very carefully and slowly (this project took most of my day today) took photos of the assembly, and disassembled it. Replaced plungers/o-rings, and air manifold. Put it all back together...and it was jammed up. Same problem he had. The problem is that you can't easily mark the gear/track locations to each other so when you put it back together it's easy to guess and mis-align them. That being said, I'm going to call Dave here in a little bit because I think he posted that he has the gear in the dead center of the track. This isn't correct, I had to pull everything apart all over again and using the photos I took earlier, positioned the lever arms in the "parked" position, and then moved the track to place the gear at one complete side of the housing. This proved to be the issue and I have a wiper that once was completely dead, and now lives! And really operates smoothly...wow...no jerky movements, just smooth and I like that I can slow it down or speed it up with the knob. I'm a believer in air wipers again. Mine are dated 1982, so they are the same age as me...33 years out of a wiper motor ain't too bad in my opinion. Here's some pics of my mess and a video of success!
VIDEO OF SUCCESS: https://www.youtube.com/watch?v=u2hftXtkUak
   I see that the new front assy has brass threaded bushings now. Mine are the old style with small cracks like your's, but not as bad. in the back ground.
If anyone wants my old o-rings and plunger inserts etc, I can send them. You could probably buy o rings locally much cheaper. Between the plastic manifold and the oring and cork gasket kit, I was out $130. That's too much money in my opinion
