Blown Turbo or oil seal
Started by Nineforever, June 20, 2015, 07:46:30 PM
Nineforever
Was just about back in the yard about 20 miles from home today , was looking out my drivers side mirror all of the sudden it started to blow blue smoke out the exhaust pipe big time smoke show i dropped my speed and continued towards home closely watching the engine temperature and oil pressure i lost a bit of oil pressure engine seemed to run fine but significant loss of power .
After pulling into the yard and shutting down i notice about 2 litres of oil drain out the exhaust pipe and oil seeping out the turbo .
Did the turbo fail
Hyway 3 100 klms south of Yellowknife NWT Canada
OneLapper
OneLapper
1964 PD4106-2853
www.markdavia.com
HB of CJ
I suppose in a twisted demented fashion you are lucky.  One thousand years from now you could have just easily blown a major plasma conduit to the main matter anti matter power converter.  Instant major fireball.  No survivors.  And if it had happened in Warp, we would NEVER have found ANY pieces.  Just me.  HB of CJ (old silly coot) :)
Nineforever
Take off the air intake/filter assembly and check the turbo. Check it for side to side play/messed up fins, and make sure it can spin on its own.
Nineforever
Called in some one to pull it out this morning , blew a turbo on my western star years back covered my windshield in oil it also had a 8v92T silver same kinda symptoms . Will now for sure latter on in the day .
Jim Eh.
If the part of the turbo shaft and the impeller are missing you will have to pull your muffler. It WILL wear a hole in your exhaust wherever it is.
Jim Eh.
1996 MC12
6V92TA / HT741D
Winnipeg, MB.
Those pictures made me cringe..
Nineforever
The oil seal failed the fins on both sides seem fine but ill change complete turbo, exhaust and intake side . Original equipment available threw Wajax Power Systems in Edmonton There the official MUI dealer here in Canada $ 2152.00 plus the core 450.00 .
A little pricey turbo, Turbo Resource in Lake Havasu Az will exchange it for 600 Tom the owner is the guy that set up the turbo rebuilding unit for Detroit.Shipping into Canada could be a problem I don't seem to have much luck with shipping to Canada
