Alignment / Suspension shop in MN?
Started by eb99603, May 28, 2015, 07:43:16 PM
eb99603
Hey busnuts. My Setra has some pretty strong negative camber. I haven't yet figured out why but I suspect once I do, the fix will likely exceed my skill level. I'm looking to find a reputable shop in the Twin Cities area that would be able to fix my issue, and probably do an alignment too. Any recommendations?
Talk to JD at C&J Bus Repair, 9010 Pillsbury Ave S, Bloomington, MN 55420 (952) 881-0034.   If they can't help you, ask for a referral.
Brian Diehl
Don't go anywhere else except to Precision Frame and Alignment in Elk River.  They are great to work with and do a fantastic job.
http://www.precisionframe.com/
When I took my bus there I worked directly with the owner.  He is a motor home owner and understands the needs of RV'ers.
eb99603
Precision Frame! That's the place I was thinking of. I knew I'd seen some place from the NW metro mentioned on here before. Thanks Brian!
gumpy
Let me know if you get up in the northwest metro. Maybe I can come play show and tell. We're in St. Michael.
