Escape hatch
Escape hatch
Started by BeastMaster, April 25, 2015, 05:57:35 PM
BeastMaster
The original builder, left the rear hatch in my MCI102C. However finished the inside headliner hiding the hatch. I would like to expose the hatch and be able to use it. Can I remove the hatch lid from the outside in order to start a clean removal or headliner?. What problems will I encounter or any better ideas. Thanks in advance.
Allan
Sent from my SM-N910T using Tapatalk
1989 - MCI 102C3 8V92TA T740
Converted by Dick Lamb, Custom Land Yachts - 2005
Famous Margaritaville Bus
Star of the Duncan Family Counting FireFlies
gumpy
Maybe. Not familiar with the 102, but here's some information on my MC9 hatch. Maybe it will offer some insight.
http://www.gumpydog.com/Bus/MC9_WIP/Structural/Roof_Access_Hatch/roof_access_hatch.htm
LuckyChow
Allan,
Which hatch does it have, the rectangular one or the square Transpec (24" X 24")?
Darryl
Smyrna GA
2000 Gillig Phantom
I have the rectangular type.  If you want to expose the hatch cleanly you would start by X-ing through the headliner in the middle of the hatch, which will give access to the handle, which is about 3" by 8".  Pop the handle down, and the hatch will flip completely out of the way.  You might be able to get the hatch off from the outside by removing the hinges, but that latch is a pretty good one, it may still hold the hatch shut, so you'd have to do the inside anyway.  Cutting a quite small hole, say 4" by 10", in the middle of the space you are going to remove would leave ample material around the outside to finish the edge, I would think.
BeastMaster
It is the rectangular type. Thanks for all the responses.  Sounds like removing hinges is not a good approach.
