Air in Power Steering
Started by qayqayt, April 20, 2014, 09:23:22 AM
qayqayt
How do I get rid of air in the power steering lines?  We had a minor leak fixed at the pump and although they thought the system was okay, occasionally on a sharp turn I get armstrong steering.
Bryan
Vancouver BC
GM PD-4108
blue_goose
Jack up the front and turn it stop to stop a few times.
Utahclaimjumper
He means turn it "stop to stop" WITH THE ENGINE RUNNING.>>>Dan ( It will purge the air)
Utclmjmpr  (rufcmpn)
EX 4106 (presently SOB)
Cedar City, Ut.
72 VW Baja towed
This is true for original hyd boost steering. Well described in the manual.
If it is Sheppard all you need do is keep filling the reservoir until the bubbles go away with the engine running.
Utahclaimjumper
 You can use the same method with Sheppard to.>>>Dan
Utclmjmpr  (rufcmpn)
Cedar City, Ut.
72 VW Baja towed
You can, but it isn't necessary. It works itself out just like auto PS.
I have a lot of experience with this because my Sheppard is obsolete and it leaks a lot:)
qayqayt
Thanks guys.  Sorry I haven't responded as we've been travelling and were off line for a couple of days.  The problem seems to have solved itself.
Bryan
Bryan
Vancouver BC
GM PD-4108
Boomer
Brian, how did your engine repair in Calif. go?  Interested in what happened.  Hope to see you somewhere this summer, how about coming to NWBN rally in the Columbia Gorge, Sept. 4-7 ?
Mark
'81 Eagle 15/45, NO MORE
'47 GM PD3751-438, NO MORE
'65 Crown Atomic, NO MORE
'93 Vogue IV, NO MORE
1964 PD4106-2846
North Idaho USA
