Push on Flare Tool
Started by luvrbus, March 26, 2014, 06:36:58 PM
   The kit I referenced will do that also;. It's somewhat pricey, but will do the job; covers several sizes and requires light hand pressure to create bumps and flares with the hydraulic tool. You just install the correct dies and allow tubing to protrude the required amount, depending if you are creating an inverted flare or o-ring flare
