BCM Forum
50DN alternator / Regulator
Started by rusty, February 20, 2014, 02:21:57 PM
Sense should go as close to the batt as possible.
If you can't find a connection for "Sense" close to the VR which has exactly the same voltage as the batt then you should run a wire directly from the batt. Otherwise the alt will overcharge the batt because it thinks the batt voltage is lower than actual.
Or, as in the drawing, connect Bat and Sense together if your Bat wire is the same as the batt +terminal.
My problem is this Bat wire is not full batt voltage so I'm going to use the cube relay to do it. The good part is my batts are just 6" below my VR.
