Duo therm interior flush mount?
Started by Jnbroadbent, January 25, 2014, 06:42:47 AM
Jnbroadbent
As I'm putting up the wiring and insulation, I remember seeing a flush mount cover that also relocates the controls to the wall. I can't seem to find anything or I'm searching for the wrong terms or something...
Anyone know what I'm talking about?
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
robertglines1
As Bob said, you are probably thinking of a ducted air system.  If it is a Penguin there is a regular air assembly that works with a thermostat, but I believe the upper unit is different too.  I would talk to an RV dealer, or see if Dometic can answer the question.
I think he talking about the Comfort Control Center and air box for Dometic any roof top with a upper unit can use a wall thermostat but it takes 12 volts and a relay to work they don't need to be the ducted units Like Bob I thought all the flush mounts were for return air on a ducted system
Taibob
I have two units as described installed in my 84-9
A/C are older Colman Roof Wart Units with wall mount Thermo's
and flush mount covers on interior ceilings.
I shall try to connect with you [PM] soon with pics,
Try me on my profile Email
Bob
84 mci 9  8v71n N70 Jakes 740 auto 2 Slides    BC/AB Canada
TedCalvert
Did this on my 87 XL, as well as heat strips. I have Colemans, but Duo-Therm probably has them as well. Look under parts and accessories on D-T website or try AmericanRV.
