Aircompresser
Aircompresser
Started by Nineforever, September 21, 2013, 09:42:42 PM
Nineforever
Hello board members does any one have the model # and make of Air Compresser on a 1993 102c w/8v92ta and 1981 MC9 w/8v71n
Dave
Hyway 3 100 klms south of Yellowknife NWT Canada
Seangie
Dave,
Could be a couple of models that fit.  I would assume there are a few Bendix models that would fit.  Do you have a compressor now that you are replacing?
'Cause you know we,
Driving through the night
To that old promised land'
Nineforever
Yes but there still in the bus and working but passing oil time to replace , able to order threw MCI but they will not give you after market part #   if i order threw MCI there approx 1100.00 less 600.00 core problem is to ship back the core to MCI from Yellowknife is at my exspence and it would be real costly .
Thanks for replys
Dave
Seangie
See if you can get the model number off the one in the Bus.  I did that and then cross referenced it through Bendix and found the replacement.  I also found later that there are better updated versions that would have fit and worked better but I kept looking for the same exact model.
My compressor had a part number stamped into the top as well as a red plate on the side of it.  Was not hard to cross reference once I got those numbers.  This is off a 1984 eagle with a silver 6v-92.   One of the more experienced mechs on the board can probably tell you what models will work in the MCI.  Give them a day or two and they will help you out.
'Cause you know we,
They are not hard to find MCI takes a a 75 degree tilt 700 or 750 cfm compressor here is a Haldex number 289915X any supplier can cross it over if Bendix is your choice same compressor will work on both engines and they are treat to replace on a MCI  ???
As said it's a Tu-flo 700 or 750 with a Detroit flange, 75 degree tilt.  OEM was Bendix, if you get a Bendix rebuilt unit the MCI price is about exactly what I paid two years ago.  You are going to have to send in the core to get a price in the $500 range.  I got mine from a local truck parts store, it was remanufactured by Bendix, which I highly recommend.
Nineforever
