Detroit Series 50 Help Needed in Upstate NY
Started by natepelton, August 16, 2013, 06:59:06 AM
natepelton
Hello again-
I have an Orion V Transit Bus with a Series 50 Detroit that I use for my rafting business. I think I clogged a couple of the injectors by running too low on fuel. I have the service and parts manuals. Does anyone know a mechanic familiar with this engine that could make a house call near Lake George, NY?
Thanks-
-Nate
Nate Pelton
1983 Prevost LeMirage
North Creek, NY
pvcces
Nate, you didn't say what your symptoms are. What you have said so far has made me think that you have run it out of fuel. What made you think that you plugged the injectors?
Some information could help.
for what it's worth.
Tom Caffrey
Tom Caffrey PD4106-2576
Suncatcher
Ketchikan, Alaska
Unless your filters are REALLY bad, the fuel level would have no bearing on your situation.
I think I would check fuel level first and then filters.
Seangie
Is it something as simple as losing prime if the fuel ran out?
www.herdofturtles.org
1984 Eagle Model 10S
'Cause you know we,
Driving through the night
To that old promised land'
LuckyChow
Those are electronic injectors and unfortunately, not cheap.  The core value on them is more than the cost of the rebuilt injectors.  Usually the filters clog up without anything getting to the injectors though, assuming you have the correct filters on it.
Darryl
Smyrna GA
2000 Gillig Phantom
