Stuck like glue!
Started by Miss Scarlett, May 14, 2013, 05:48:47 PM
Miss Scarlett
Is there a secret to getting the turbo housing and the cast iron exhaust elbow apart. You would think mine has been welded together. I removed the v-clamp and have done all I know to do to try to get them apart. Any special tricks or suggestions?
Dan
Miss Scarlett is an Eagle 10 with a 6v92 and Allison 740
UPDATE: finished enough to use!!!- exterior will remain original.
-Dan
Acetone and 50/50 mix of ATF or PB soak the piss out of it, take rubber hammer it should come apart,heat is the next option
Miss Scarlett
Thanks, I have PB on it now and will do the mix you suggest tomorrow.
Dan
-Dan
Zeroclearance
You most likely will need to add a heat cycle to the process..   Soak, heat, soak..
Miss Scarlett
Will start with heat in a day or two when i can get back to it. Tried the big new rubber hammer I bought today. For a minute there I'm sure I could hear it laughing at me...
-Dan
No leak there Dan lol you need to go down with the hammering not out, I secure the turbo someway and beat down like trying to turn the 90 it can be a chore
Miss Scarlett
I have it soaking in the 50/50 solution but can't get back to it until late tomorrow. Work is getting in the way of my bussin. Will give her another beatin' when I get home.
-Dan
Miss Scarlett
It is apart! ;D The new exhaust flanges should be here Monday, the turbo is being built by Tom at Turbo Resources and my pillow block is at a friend's shop. Cleaning all the rust off the mating surfaces on the manifolds and the turbo base is done so hopefully it will go back together easier and cleaner than it came apart.
I do have one area about 1" wide where the left side pipe mounts to the turbo base where the surface is pitted. That will probably cause a weak seal for the new flange and will probably leak and burn it out before too long. What about using some kind of sealer in this area to insure a clean, leak free fit? Anyone know of a sealer that will hold up in those temps?
-Dan
Dan, I am not at home but patch it with something I always build those up by welding and grinding it off do a repair for now and I have a dozen of those I'll send you one for the freight charges when I get home it is a 2-1/2 not the 3 inch ?
wg4t50
Always thought a coat of anti-seize during assemble might help, of course I never did it.
Dave M
MCI7 20+ Yrs
Foretravel w/ISM500
WG4T CW for ever.
Central Virginia
Miss Scarlett
The pipe measures 2 7/8" to 3" depending on where you measure it. The flanges ordered are 3" x 3 1/2". I took it to a parts store and a pipe shop and they both called it 3".
I probably wont get it back together before the 2nd week of June so I have time for you to send me one. I could have mine welded and ground off. Would that be as good as an original piece?
-Dan
Miss Scarlett
Clifford, I sent you a pm
-Dan
Miss Scarlett
Clifford, did you receive my PM?
-Dan
yep tried to answer you but it is back in my box it will be the middle of June before I am back home then I will ship it to you
Miss Scarlett
Thanks, I will be looking for it.
-Dan
