Air vs hydraulic cylinders??? - Page 2
Started by bevans6, March 22, 2013, 06:14:34 AM
Low Class
Dumb question:  what are the advantages of an air closer over a simple latch?  Does it seal the door more airtight or what?
Jim Keefauver/1985 Wanderlodge PT36/6V92TA/MT654CR/East Tn.
That same Brill I had had an air operated clutch. It used a Bendix pedal, same as the brake treadle, and used a Rotochamber attached to a homemade mounting bracket at the bellhousing, connecting to the clutch arm and only had an air line from pedal to chamber, and supply to pedal. Worked fine with low pedal pressure. I would have used the same setup on the 4104 but it already had an air assist clutch.
Emcemv
One source that I have used for air cylinders and linear actuators is at www.surpluscenter.com they have all kinds of neat surplus stuff.
Bruce & Nancy Fagley
1973 MCI MC-7 Combo Freighter
450HP DD 8V-92T 2000 Reman
HT 740 Allison
Woodbury CT.
