Over Temp shut down
Over Temp shut down
Started by Kwajdiver, March 14, 2013, 07:58:49 PM
Kwajdiver
My 6v92 shut down due to "over temp", due to the miter box at the blowers failing.
The box, gear, is being replaced.
The question, does the over temp shutdown, before the engine can be damaged?
I'm sure that is the design, but does it work?  At what temp, do they normally shutdown?
Thank you for the information.
Bill
Auburndale, Florida
MCI-9
Kwajalein Atoll, RMI
junkman42
Bill, if You still had full coolant You should have no problems!  Big difference between shutdown for loss of coolant and problem like You have had!  Hope all goes well for You.  John L
They shut down around 208 or 210 like John said if he coolant level is ok no harm no foul no coolant they just set and fry
Kwajdiver
No coolant was lost.
Thanks Bill
Auburndale, Florida
MCI-9
Bottom
Bottom2
