Replacing rusted supports on a MC9 (U channel or tubing
Started by Jnbroadbent, January 10, 2013, 12:07:50 PM
Jnbroadbent
Several of the horizontal braces (about 8" off the floor) have rusted through, I cut em off and prepped for welding new ones on. My original plan was to use 16ga 1"x2" that I found locally for $1/ft then I found some  Flanged U channel similar to the original factory, 1/8" (between 10-11ga) locally for the same price.
I am thinking the u channel since it's thicker, will be a better choice.
Any thoughts?
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
grantgoold
I would use the heavier duty stuff if I had the choice. The trouble you have already gone through to get ready to weld tells me to error on the side of caution and beef up the supports.  Would be a bunch of work to latter on see flexing on the side of the bus caused by too light a material.
My thoughts!
Grant
Grant Goold
1984 MCI 9
Way in Over My Head!
Citrus Heights, California
Jnbroadbent
Quote from: grantgoold on January 10, 2013, 01:48:05 PM
My thoughts!
Grant
I would agree with you! I probably just needed to type out a justification, I kind of knew the answer all along. Thanks!
Jon
1980 Mc9 w/ veg oil
8v71
Jacksonville Fl
